Yes, the loader is practically new and the hood is new...the rest of the plastic panels have faded a bit, and the front left has some cracks in it. I'm not too concerned about that (as long as the panel isn't falling apart).
I hit the treadle grease zerk with some grease...seems a little better now...but I'm thinking I still might need to add a little tension to the spring. It getting stuck unexpectedly can be a little dangerous, so I'd rather be pretty sure it's gonna center back in neutral.
The brake lock is just a steel rod sticking up out of the floor on the left side of the platform...did this used to have a small pedal on it perhaps? I believe I've been driving it around with the parking brake at least partially engaged...clearly, that's gonna need a little adjustment now too. I'm still not clear on exactly how it's supposed to work...do you step on the brake pedal, then this pedal/rod to lock it? Then push the brake and pull the rod up to unlock it? Or push the brake pedal and step on the brake lock again to unlock it? The brake pedal itself doesn't seem to return...I'll bet the hinge is either corroded, or the spring needs adjustment or is missing.
Cheers,
Dave
Cheers,
Dave
