Does anyone here know if a 4672a backhoe will work well with a b2601. Someone's selling one online but I can not find outfits compatible with my tractor.
That's probably appropriately sized for your tractor. HOWEVER, most everyone here will recommend against a 3ph mount backhoe. They concentrate the vertical loads into the top link point and have been known to cause broken housings. Frame mounts avoid this and are available for the B2601 with the appropriate hoe.
If you pursue the 3ph version, make sure you buy or build the top link bracket reinforcement.
