A couple of months ago my B7800 ignition switch was acting up. It would turn on, activate the glow plugs but not trigger the solenoid on the starter. Sometimes you could get the starter to work by wiggling the key. The tractor would start by crossing the positive terminal to the solenoid terminal. So I thought the switch was bad as indicated in a few posts here. I bought a new ignition switch and installed it. It worked for about a week and then stopped just like the old one. All the fuses are good, and I changed them anyway.
The last two times I used the tractor I started it by jumping positive to the solenoid. After I blew snow for about a hour the starter would crank with the key. That worked so long as the tractor was warm. This morning I tried again to crank it and no dice when it is cold.
Any thoughts from the experienced on the forum.
