What's your opinion on the paint? Do you think it needs more time to cure, or did I make a crucial mistake of some kind? I mixed the primer per the instructions on the can, and for the topcoat I went 5:1 acetone instead of the 15% that is recommended. Thought that would be better since the weather hasn't broke high 50's here till yesterday when we hit at least 65I have no issue with Rustoleum at all. Mine dries hard but then I do the light first coat, let it flash off and then top coat which is what I always do anyway and then I let it sit in the sun and cook for a day or so.
I too did two coats. Let it flash in-between. Sat for 24 hours in my "booth" with the fan running and the hot sun on the trailer. I'm wondering if the primer somehow is reacting with the paint? I doubt it as they are both oil based, had to use majics primer as I could not get a good batch of the Rust-Oleum stuff.
One thing I learned was, no matter how good the respirators were, a bit of atomized product always leaked past them.
Tell me about it, I got a pretty long beard, so whatever particles that try and make their way through stick right to my beard. Luckily my beards orange as it is! Lol
I see you masked your wheels like I did. If you ever do that again, run the taper carefully along the edge of the rim using your fingernail to secure it. Much easier than trying to get it to lay against the tire. You only need a couple longer pieces of tape that way
Great idea. That wouldn't have worked on my rears though as the tire presses out beyond the edge of the rim. I'll have to keep that in mind next time. Came out great though!
