I have been chasing down the cause of low oil pressure on my 1986 B7200 HST 4WD.
I've changed the sending unit, pulled the timing cover to inspect the front cam plug (it was intact), replaced the oil pump and oil pressure relief valve, but still have only about 12 psi (at idle) and 24 psi (at 2500 rpm) when cold, but it drops to about 4 psi (at idle) and 10 psi (at 2500 rpm) when warm.
I don't have the know-how to get to the rear cam plug, and the local Kubota service guy says there is only one on the front anyway (although the parts manual shows one on each end). He says an engine overhaul is the only option. The engine runs and sounds fine to me, but he says it's noisy when throttling back down, indicating mechanical wear. Should I insist he check the rear cam plug, since if that's missing an overhaul might not be necessary?
