B birdog New member Equipment B7200D Feb 28, 2014 21 0 0 Pekin, IL Aug 2, 2014 #1 Will my B7200D 4WD handle a 5ft Disc? The disk is a Dirt Dog 60" and weighs 530lbs. I'm curious how much weight my lift arms can handle.
76_Bronco Member Equipment B7200 4WD w/FEL, 4' disc, 4' Brush Hog, 14" Plow, 4' Blade, JD 246 2 row Planter Mar 28, 2012 182 1 18 Rainsville, Al Aug 2, 2014 #2 birdog said: Will my B7200D 4WD handle a 5ft Disc? The disk is a Dirt Dog 60" and weighs 530lbs. I'm curious how much weight my lift arms can handle. Click to expand... The rear lift on mine can handle 650lbs, so you shouldn't have any problems as long as you have some weight on the front of your tractor.
B birdog New member Equipment B7200D Feb 28, 2014 21 0 0 Pekin, IL Aug 5, 2014 #3 76_Bronco said: The rear lift on mine can handle 650lbs, so you shouldn't have any problems as long as you have some weight on the front of your tractor. Click to expand... Thanks Bronco
