I have a b7100 and I just replaced the o-ring for the 3pt piston and now the 3pt doesn't move I know I have the valve in the right direction. I think I need to blend the cylinder. How would I go about doing that?
Thank you sir. I believe the o-ring is sealing good. I put a new o-ring under the valve and it is a little thicker than the original one could that be the problem?
