B2920
slickwilly1976
L1500,L1500dt, B2920,bush hog,tiller,scrape blade,cub lo-boy
Jul 14, 2013
Rocky face Ga
OK I just got my mmm for my new B2920 about two weeks ago. As you know In order too use the mid PTO you must loosen a bolt and slide a metal bar over too the right so the PTO leaver can be pushed forward to turn the mid pto on. My problem is sometimes the leaver pushes forward easily but other times it will not move forward at all. Its like the safety bar still has it locked but its not. The leaver will always slide back for the rear PTO with no problem. Before I took it back to the dealer I was wondering if anyone else had this problem.
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
308
261
catlettsburg, ky
Are you talking about the bolt that changes pto speed to 1000rpm?
If so then you don't need to make that change.
Your mid-mount pto is set for the proper rpm.
That 1000rpm setting is for the rear pto.
slickwilly1976
Jul 14, 2013
Rocky face Ga
You have to shift the PTO leaver foward to turn the mid PTO on and backwards to turn the rear PTO on.
slickwilly1976
Jul 14, 2013
Rocky face Ga
If you dont shift the leaver foward then the mid PTO doesn't come and if the mid PTO doesn't come on then the mmm doesn't come on
beckmurph
Aug 23, 2012
308
261
catlettsburg, ky
You mentioned moving the plate by loosing the bolt down under the pto lever. I never moved that plate. It was set for 540 rear and 2500 mid, and moving that plate to another position would give you a third speed for the rear pto.
Are we talking about the same think?:D
