B2601 quit
johncrumbie
Covington, GA
Used my B2601 today for several hours nonstop. Mowing with MMM. Finished and got off to let it idle to cool down as I usually do. PTO off. Was idling, flipped seat forward and it shuts off immediately. No response from ignition switch other than glow plug light.
Battery has good voltage, checked fuses. Checked seat safety switches as well as I could. PTO still off. Tried everything in neutral.
Will try and recharge battery tonight though it shows 12.5 volts.
Any ideas as to what I'm overlooking.
3,874
I have a BX, but it takes just a little bit of movement in the PTO lever to prevent a start.
It’s also not a bad idea to rock your HST pedal to make sure something isn’t a little wonky there.
Jchonline
596
Red Feather Lakes, CO
So if you dont touch the seat it idles fine, but if you flip the seat it shuts off?
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
231
80
S.E. TN
No doubt the PTO or HST switch is causing this.
Dave16
14
Follansbee, WV
Was the issue with your B2601 resolved? Mine is doing the same thing now but it will restart. I've replaced the safety switch on the PTO but still doing it.
