Auxiliary work lights on LX
CFarm45
LX3310, ZD21
Jul 19, 2021
27
14
Western NY
This question is directed specifically at the LX ROPS owners. Where did you mount your switch(es) for auxiliary work lights? I’m installing forward and rear facing lights on the ROPS and want to have them switched separately (2 switches). Thought about the dash above the factory light switch, but saw on YT someone pointed out there is a support in the way there. (Haven’t pulled the dash off to see for myself) Thought about the plastic on the fender surrounding the 2/4wd selector, but couldn’t find a spot there I was really happy with. I like things to look clean and tidy, like they might have come from the factory. What have others done? Thanks!
3,503
B2650 here, but, should be the same. Mounted switch just above the factory light switch. The switch is illuminated when the ROPS lights are on.
used these. Mounts are magnets and they work great.
CFarm45
LX3310, ZD21
Jul 19, 2021
27
14
Western NY
That was my initial thought, then saw a YT video where the guy said there was a support in the way behind the dash there. Guess I’ll have to pull the dash off and look for myself.
3,503
It looks like the same as the B2650 if memory serves me right...
i7win7
Feb 21, 2020
3,379
3,981
Central, IL
You will find all kinds of things a high amp 12v rear power can run.
4,781
My BX2360 ROPS is less than 6’ tall. Put them on top. 2 forward/2 back.
Cobbled them up years ago off the 10A work light circuit. Some 6” brackets and other parts I had kicking around.
On/off in 5 minutes. They’re off during mowing season. Just put them back on.
I’ve been tempted to put two light bars in the place of the 4 squares, but really don’t need to…..;)
Daferris
LX2610
Nov 23, 2021
481
401
Mid-Michigan
For my LX2610 ROPS I used the lights and the switch below in the screenshots. I welded a short piece of 1" angle iron to a small flat plate that I bolted to the existing holes in the ROPS that the factory light kit uses.
The switch I mounted just below the parked PTO button after removing the knock out (note mine was glued to the dash so it took a bit to cut it loose). NOTE the switch is not waterproof but if it ever fails it's not hard to get to it to replace. Also in my case I park the tractor indoors. Snow would be the biggest concern but I think it's unlikely to be enough to take out the switch. Note next to the Right side ROPS bar at the fender is a +12volt 10 amp fused circuit that is switched by the ignition. The ground wire is there as well. It is where the factory lights get there power.
Showmedata
LX3310
May 18, 2022
190
152
Boulder CO
Dash mounted the switch just like @dirtydeed - there was plenty of room in there and R&R of the dash panel was pretty easy.
I didn't want the lights above the ROPS because I'm always running into tree limbs. I mounted the 4 lights to a bar then attached it to the ROPS with 2 rivnuts and some solid spacers, to minimize the number of holes drilled in the ROPS.
Front and rear are on one circuit; the only time I operate in the dark is clearing snow, and having them all on makes sense for me.
jkrubi12
B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/WC-68 Chipper
Sep 24, 2012
397
289
right coast
FWIW, this is my setup on a B2601. The switches are from the same wiring package as posted by dirty deed (mine was a double switch kit), great switch/wiring package! (y)
Showmedata
LX3310
May 18, 2022
190
152
Boulder CO
Great. Thank you. Out of curiosity, What is the blank under the switch?
Unused factory blank, according to the manual (I couldn't remember). On the cab model, it's the "beacon switch (if equipped)". But it's the wrong shape for my round switch, so I drilled.
CFarm45
LX3310, ZD21
Jul 19, 2021
27
14
Western NY
View attachment 89125 View attachment 89126 View attachment 89127
Thank you. I had pretty much decided on very similar to this OR the dash mounted switch. Question for you… were you able to get the plastic entirely off the fender or just lift it enough to get the switches mounted? (To remove completely, I think I’d need to remove the selector lever knobs, if that’s even possible).
jkrubi12
Sep 24, 2012
397
289
right coast
Got the plastic entirely off the fender, the selector knob 'ends' slip right off the ends of the levers.
4,653
4,781
For the OP, a lot of folks have posted some very impressive photos of work lights.
Mine are pretty rudimentary, but they do their job. I’m sure you’ll be happy with an upgrade.
I did LED headlights years ago. They are better than stock and use less amps, but useless when the snowblower is on. Lights the back of the blower and little else.
This is LED on front and back. They’re not aimed yet, but gives you an idea…Well-worth the effort however you choose to go about it.😉
