Hi all, new member looking to buy my first tractor and could use some advice. Our property is relatively small, just over 2 acres, heavily wooded and some areas fairly rocky, Other areas are soft-loamy so I feel weight would be an issue during the wet season.
We plan to build a house next year so some of the uses will be moving and leveling 100+ ton of road base (160’ driveway), backfilling water, sewer, utility trenches, moving some of the large rock (300-600 lb), grading front drainage ditch, other misc site work. At some point will probably end up with a stump grinder as well.
I’ve been looking at the LX2620HSD, I like the lighter weight for the soft soil. Just not sure how well the lighter tractor will do moving the material I have. I’m ok with moving smaller amounts, time isn’t too big of an issue. Most of the tractors in the neighborhood are JD 1023’s or similar and they are happy with them as far as maintaining property. I think I want to go a little bigger mainly for comfort.
So just trying to get some advice and make sure I’m on the right track.
