I want/need to be able to pull a surplus military trailer (M101) around my property. Not just move it around, but use it. I seen a thread somewhere but can't find it now, saying that this was not acceptable because in certain off road situations the trailer tongue weight could go negative (trailer too heavy on rear end) and cause the 3pth arms to lift or even slam all the way up. This could cause damage to the tractor or even cause a tractor wreck.
Could you not make some sort of provision down to the factory drawbar that comes out from under the PTO shaft and limit the amount of upward movement the 3pth could have?
This trailer mover looks to have a setup for that very thing. Looks like you bolt the chain to the drawbar to limit upward travel?
