1991 L2550
Hopefarm
Jun 7, 2022
when operating in a low load situation she stalled when I retried to start when cranking everything sounded as it should but once it started it sound like a piston broke loose and was banging ( this is what is sounded like to me) some one suggested it could just be water in the diesel fuel is there a separator separate from the fuel filter i is this a possibility or just wishful thinking it has 700 hours on it
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
I don't know what "a piston broke loose" means. If you spin a bearing the piston can slap the head. Obviously that should not happen at 700 hours. Rather than cause further damage it's time for a visit to the shop if it's not just water in the fuel.
6,420
Yea no way water in fuel will sound like a broken piston.
What kind of low load situation?
PTO use or moving or ????
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,236
1,018
Williamstown Ontario Canada
If it were my tractor I might be inclined to remove the valve cover to see if an adjuster has come loose.
It seems like the least involved next step.
Dave
Hopefarm
Jun 7, 2022
to be honest I dont know what a broken piston sounds like - when I turn it over she sounds just normal but when it fires up you would hear the noise so my friend who was trained n diesel in the marines that was his thought
Hopefarm
Jun 7, 2022
pto was not involved I was pushing the top of a pile of some horse manure
6,420
Make a video of it cranking starting with the noise, post it on YouTube and give us a link to see, hear it.
Could be as simple as a failed injector.
Any exhaust smoke now?
Did it get hot?
