Installed a block heater
2,551
Looks great - in your neck of the woods it will make a world of difference!
jajiu
Jun 5, 2016
456
112
Rowley, Massachusetts
I had one installed on my L3560HSTC before last winter and loved it. I put in a remote switch down to my barn, about 30' from the house, and I can turn it on from the house and while I have my coffee and breakfast it warms up and is ready to go.
mrcarnage2
B3300SU
Nov 13, 2017
40
Pullman, MI, USA
Where did you get the remote switch from? I would like to install one for mine as well.
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
309
79
Bagley, MN, United States
One option for a remote switch provided by an OTT member -
Receiver : https://smile.amazon.com/gp/product/B0051BTTP0/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
Transmitter : https://smile.amazon.com/gp/product/B0052RO58O/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
The description indicates 500' range for transmitter, but mine is about 240' through glass at both ends and it barely works - I attached a light to the receiver also so that I can determine when it is on. There are other transmitter models that have 1 or 2 buttons, but for the price difference I selected the 3 button transmitter for adding additional receivers.
5,584
Based on other's experiences, it would be wise to have your parked tractor in neutral so there is no chance of it moving off when you start it from a distance!
There was a post here about a month ago about an HST that slowly creeped out of the storage area unattended.
rjcorazza
Mar 9, 2016
778
24
Hyattstown, MD
If your machine is within wifi distance, look at Wemo wifi outlets. I have several, one of which does block heater duty in the garage. Programmable on/off or remotely operated via an app.
Stmar
B2650HSDC
May 23, 2017
929
47
Buffalo, Wyoming
I think he was saying that he turned on the block heater and not start the motor. I used the same set up only with a single button transmitter, cheap option for warming up the Kubota without having to brave the cold. My barn is 300' away and I have to be in certain positions to turn it on, have a light as the other poster said to make sure it comes on. I leaned about this from a previous thread quite some time ago so if you want to reread do a search to see that discussion.
jajiu
Jun 5, 2016
456
112
I got it on line, not sure if it was Amazon or not, it was a couple of years ago. It has a remote and an outlet to plug the block heater into. I set it so there is a low watt bulb plugged into it as well and hung it in the window so I know that the switch worked and the block heater is on.
jajiu
Jun 5, 2016
456
112
stmar, you are exactly right. I read the thread you are talking about and got the idea from that. I searched around and found the one I have and it has worked well for the past couple of years.
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
I installed a block heater and a battery blanket on my JD. Then routed both of them to one convenient plug mounted under the steering wheel....
The small plug on the right, is for the battery tender. The large on the left powers the block heater and battery blanket.
