3 Point Log Skidder
phildac
1984 B8200E, L260F
Jul 29, 2009
203
Wentzville, MO
Anybody out there build your own log skidder for your 3 Point Hitch? Looking for pics or plans.
Picked up these skidder tongs for $40 new and want to make a skidder.
Thanks,
Phil
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
You could get a boom pole and pick up one end of the log so it would dig a ditch in the ground as you drag.
6,397
Yea use a boom pole...
I bet I'll be able to tell you the color of face (sheet white) and your shorts (poo brown) when your done trying that!:rolleyes:
If your trying to use your B8200 as a skidder, I hope your talking the proper 3 point skidder.
Using logging tongs off the back of a small tractor can be pretty scary if not done right.
Here are a few different models to copy from if you still want to try it.
Bluegill
Jan 11, 2012
1,560
Success Missouri
No pics, but I made a simple short boom pole to skid with on the L3800. Works great!
Some very good photos above!
phildac
1984 B8200E, L260F
Jul 29, 2009
203
Wentzville, MO
Thanks all,
Yeah, I googled it and saw those pics too. Just thought someone might have had a different idea. I bought some heavy tube stock to build one which is alot cheaper than the boom pole. $30 in steel. Just want something to lift the front of the log up a few inches to clear. Have plenty of weight up front plus check chains to keep it from pulling up too high to prevent unwanted rollovers.:D
Kingcreek
Grand L3010 GST 4wd, LA481FEL, various attachments and accessories
Aug 3, 2011
457
NW Illinois
I made an A frame that locks into my quick hitch and has a clevis at the top for a chain or strap and a ball hitch at the bottom for moving or hauling a trailer. The clevis at the top works great for a skidder with just a chain alone or with chain and log tongs.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
I trust you all know what North Idaho Wolf man means. I also trust you know the risks of pulling anything from a point above the axle level. A loaded front bucket will do wonders to make you safer. The lower you leave the log, the safer you are as the tractor tips up over backwards.
In any case make sure the wife has kept the insurance premiums paid.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Well with some simple of ones head a boom pole will work just fine if you run a chain from the end of the pole to the log and lift it up just enough to drag it. I didn't mean to pick the entire log up.
WFM
L3800
Apr 5, 2013
1,342
671
Porter Maine
Thoses are the same logging tongs I bought a few months back Phildac...they work great and I used them today as matter of fact.
Piker
2012 Kubota 2320, 2002 Honda Rubicon
Dec 1, 2010
164
Riverview, NB, Canada
I built one for my 1980 B7100D a couple of years ago (and posted on here at the time). The chain passes through the tow loop on the trailer hitch & then hooks at the top of the trailer mover/skidder - lifting with the 3 point but pulling down low from the trailer hitch. That winter I used it to skid out 10 cord of Maple logs for firewood. Perfect conditions as a couple of hard freezes had solidified the swampy areas & there was 6 or 8 inches of snow which made skidding easy. Never once did the front end attempt to lift up even while climbing an incline. Little tractor was amazing with what it could lift/pull & hardly had to clear any trails to get around to the logs. Had a ball!
phildac
1984 B8200E, L260F
Jul 29, 2009
203
Wentzville, MO
Finally got around to building the skidder last weekend. Cut and welded the pieces on Saturday and painted Sunday. I made it to fit my T-Bar with the 2" receiver. I used 1/4" thick 2"x2" square stock. I'll add a check chain from the draw bar to the log to help keep the front tires on the ground.
3,325
Yeppers that looks good,, I could have used something like that in the fall
Bluegill
Jan 11, 2012
1,560
Success Missouri
I remember seeing your rig a while back. Amassing what these small Botas can do when set up right. :cool:
