Engineering Help needed. Kubota RPR kit -No details.
whitetiger
Nov 20, 2011
2,588
1,102
Kansas City, KS
Re: Update pic- The Fix is in...Engineering Help needed. Kubota RPR kit -No details.
OK, the 4590 is all done. It took awhile to get this thing done.... Below are some pics of the dipper boom assy and weld up.
I also had to repair the boom swing Cyl which leaked. Then elected to just do the curl, dipper, and stablizer seals too. So, done, runs like new(ish), and... greased top to bottom. what a fun mess that is getting all the old dirt-cake grease-mortar out..(my own fault).
Pics of the dipper/boom repair fab-up. Welded in the new pin Boss to the dipper, then placed the larger support ring and welded inside and outside to dipper. Some grinding clean up to meet the 3.85" OD max space in the boom receiver. Pinned and greased... solid as a rock. No more beating anything latterly beyond a nudge!
pic 1: https://d
rive.google.com/open?id=1KNqUesP_AULDACb5StsGNnG2sA_YHjqP
Pic2: https://drive.google.com/open?id=1X8k5e9U2EG8XyeLCZ2tdgycgxj3rxwN3
Pic3: https://drive.google.com/open?id=1Q_9GVmL7MGkOOAw-zmGtjCmcQGAaU2OY
Looks great, I hope you painted the whole backhoe while you had it apart!!:D
shootem604
Apr 23, 2018
875
British Columbia
I don't think these were Arens built backhoes, maybe Ameriquip or Arps?
Lencho
B7100hst
Jan 21, 2017
407
85
NM
Ok now, can someone get the photos into the post so they are available if the google links fail in the future? :)
countryguy
L2550/FEL/BH M6060/FEL ++
Nov 23, 2018
38
Fenton
Would have loved too. What’s the trick these days? Pic size upload total was so limited or is that a result of my rank? Tried putting into word doc and converting to pdf even. Still maxed above limit. (Way). I’m sure it’s listed on the sticky’s but I’m just so dang busy. Toss in via URL link was all I had time. Sorry all. Gimme a solution and I’ll get er’ done. ***129299;
SidecarFlip
Banned
546
Contemplating which avenue to take on one of my loaders that has sloppy pivots. Kubota don't offer a bushing kit for them at all so it's probably line bore and bush but I do have options. I can bush with 660 CA bronze inserts or go all out and bush with Thompson caged roller bearings with new pins of course.
