Just bought a 2003 Kubota L3130 tractor and need to remove the turn signal switch in order to remove the dash. I'm sure it's simple but I'm at a loss. Anyone have experience with this that can offer advice? Thanks in advance!!
Some times the knob pulls off and then there is a nut that holds it on. Others hook to the face with a nut on the back side. Post a pic of it and someone can probably tell you
Thanks BAP, couldn't find a screw and the center would separate from the switch, so got brave and just pulled straight up. Seems it just snapped on, but you had to put some pressure on it for it to snap off. Thanks again for your and Daren's assistance.
