Charge delivery pipe 2 issue Hst hydraulics
Getorange
9
Portland,or,usa
Bent my charge delivery and ran out my hydraulic fluid. Was thinking about removing damage section and and using rubber tubing and clamps to span the gap. Should I be worried about pressure causing hose to pop off??? Is this a bad idea for a short term fix?
Cathy Liebchen
KUBOTA L3901, MX5800, MULE PRO FX, MULE PRO FXT
that won't work, just replace the pipe. The part is not expensive.
We bent the inlet pipe on our MX and it was only $45 for the part and an hour of work
4,853
What model tractor do you have?
