Guys, when I dump or curl the bucket on my B2920, hydraulic fluid leaks out. Remove the cap from the one that leaks and half of the metal spool rod falls out. Dealer tells me I have to buy a $900 new loader valve. Is that true?
Yes the spools are not individually replaceable, because they are machined to match the block, or visa versa.Guys, when I dump or curl the bucket on my B2920, hydraulic fluid leaks out. Remove the cap from the one that leaks and half of the metal spool rod falls out. Dealer tells me I have to buy a $900 new loader valve. Is that true?
Yes that gives you a lot more flexibility.Yeah, that's what I figured.
I think the aftermarket options would work if the loader valve was mounted to the loader arms, right?
