Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 03-01-2015   #11
Trkr
1st Yr. Apprentice
Trkr's Avatar
Default Re: Glow Plug Light
Quote:
Originally Posted by Confused8122 View Post
Just to clarify, my relay was good, but my controller was bad. The controller gives ground to the relay to power the glow plugs. It also grounds the indicator to turn it on. I cut the two ground(control) wires, and hooked to a grounded momentary switch.
That way I didn't completely remove the controller, it would be easy to revert back to factory. And the controller won't make the indicator come on all the time.
Thanks!Understood.
__________________
L-2900
Trkr is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-30-2015   #12
hackw1rm
New Member
Equipment: L3600 GST
Im having this same issue, glow plug light comes on and stays on. During use the light will continue to go on and off. Thinking this might also be draining my battery because it continues to die on me. Is yours still working correctly or did another issue arise?
hackw1rm is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2020, vBulletin Solutions Inc.
