L185DT Bellhousing Drain
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
I have never worked on that model tractor before but all the ones that I have it has been easy to spot. It should be right in the bottom of the case directly under the clutch. My B 7100 just had a small bolt in it that looked like a oil drain plug. My others look more like a standard size oil drain plug but all have been right under the clutch housing in plain sight. If you have a FEL it is a little harder to see than one that doesn't have one.
