A while ago I built a capstan log winch(link is to another's build but my pics are in there too). It's had a few revisions since then but I think it's finally up to the task to start actually pulling some logs.
Good thing too because we're in the process of building our own house and I've made the foolish decision to try and make my own hardwood flooring. Now, before you yell at me, this is why it might just work out: A) I'm already going to get a bandsaw mill for other reasons. B) I have nearly 2x the necessary amount of red oak that has blown down in storms this year from all the rains. And C) I'm already planning to get a nice heavy duty WoodMaster 18" planer/drum sander/moulder to make the interior moulding out of a big spalted maple that I lost in those same storms. An upgrade adds 3-sided moulding capabilities which allow me to make flooring boards in volume (albeit a lot of work).
Now here's the fly in the ointment.... all those big beautiful lovely oaks didn't fall down anywhere near the house... or even near my roads. They are on hillsides and in the valleys so getting them out is going to be a challenge.
Enter the log arch: So far, I like the LogRite Fetching Arch the best. What really sells me is their design that allows you to winch the arch up the hill and then mount a hitch to it. However, since theirs is priced crazy and I don't think I need quite as much size or capacity as theirs I can simplify the build a good bit and make one myself (helps that I've since learned how to weld).
I'm hoping my fellow capstan winch fans will chime in here as well as any other builders. Here's a thread over on Forestry Forum on a home build that's actually pretty similar and looks to have turned out really well.
I welcome any thoughts from the brain trust. My requirements are:
Here's a mini map of my place, the dots are red oak (red), chestnut oak (orange), and white oak (white) trees that I've already measured and made sure weren't rotted out. As you can see from the shading, some of those spots are pretty steep.
- up to 24" diameter (realistically, most are <20")
- max length of 16' but most will be 10-12'
- narrow track and able to navigate rough terrain, especially steep slopes
- 1,000lbs max(ish)
- design keeps as much of the log out of the mud as possible
- able to pull for a decent distance. Most of my logs are up to 1/2mi away from my log yard
