Strongest pulling configuration
5,098
Carbide toothed chain saw!
It will tear that right up without dulling the teeth. ;)
bird dogger
Vendor Member
Feb 24, 2019
1,571
1,416
North Dakota
Like these:
Exactly, Lil Foot!:D I gave mine away years ago cuz I hadn't used it for quite some time. Now I need to fabricate another because I could've used one numerous times in the last year or two alone. I didn't have any pics of it to post. Thanks for posting your pics!!
Edit: Using a stone boat is the next best thing to having a set of wheels under the object you're moving! :D
bcp
BX2360
Apr 20, 2011
645
77
SW WA
Pull from the rear drawbar as mentioned, but put as much weight as possible in the bucket to increase front traction.
Bruce
Kevin1
Husqvarna MZT 52, BX2380,FEL, Box blade, Landscape Rake
Dec 15, 2017
127
New Bern, N.C.
Didn't even know they existed. My next stop is Amazon. Ordered a Dewalt 20V sawzall last night with some pruning blades. Of all the tools I have in my inventory a sawzall has managed to elude me. Not anymore....
shootem604
Apr 23, 2018
875
British Columbia
When I was a kid, my grandpa's old stoneboat (a VW bug hood) also served as our toboggan behind the tractor in the fields in the winter.
Mlarv
BX23S
Jan 19, 2020
218
176
Crossville TN
I have that one and use the heck out of it. If you want real good run time on a battery get one of the 60V ones and use it in the 20V saw. It is 9AH and adds just enough weight to make it not vibrate so bad when under a load. I have the 60V chainsaw and love it. I can set it down and not have to worry about it starting after sitting just pull the trigger and cutting you will go.
NHSleddog
B2650
Dec 19, 2019
2,149
1,823
Southern, NH
Strongest pulling configuration?
They are local to me so I would go this route,
I am not sure if you could get them to travel though.
I miss all the old winter commercials from Budweiser.
quazz
L3800 and Z411
Jan 6, 2014
296
Rockley, NS
If my backhoe is on I pull things with the bush bar in the front. It seems very solid and low. I do not like pulling things with the loader bucket. If I had anything really heavy i would take off the backhoe and use the draw bar.
bucktail
Jun 13, 2016
1,233
177
MN
Back in the 70s they did a 40 horse hitch
Kevin1
Dec 15, 2017
127
New Bern, N.C.
Reconfigured tractor for more of a pulling configuration, also started dismantling the stump root network with my sawzall and pruning blades.
BigG
Sep 14, 2018
1,949
765
West Central,FL
Good job, that looks like it will work a lot better then the FEL for pulling.
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
Moved a lot of rocks using a sled. I found a sheet of good plywood cut to size worked well and did not permanently mark drive or walk ways that always get in the way. Painting them with floor enamel made them slicker and last longer.
3,031
Old piece of R-panel or corrugated-tin also works well if he fwd end is bent slightly up. (If pulled on a short-chain/strap bending it up is not even required as the fwd-end is lifted as it is being pulled.) Clamping a chain or strap to it with C-clamps or Vise-grips is a quick-and-dirty sled.
quazz
L3800 and Z411
Jan 6, 2014
296
Rockley, NS
I love the idea of a car hood as a sled! I have a massive flat rock I want moved and I was considering using logs as rollers. It is the only rock in my field and I have it dug up and lifted it on end but the project stalled after that. I can't wait for spring to try this sled.
According to the farmer I bought my place from this rock has been an annoyance to generations of farmers. It was just too difficult to dig up and move versus just working around it.
Thanks for the great old method!
BigG
Sep 14, 2018
1,949
765
West Central,FL
Isn't the ground frozen now? It would be easier to do with frozen ground under the sled......hood.
quazz
L3800 and Z411
Jan 6, 2014
296
Rockley, NS
The rock is frozen into the ground. It is on end but it still in there pretty deep on that edge. Otherwise yes this would be the time.
OLD GAR
MF210, FORD 8N, BIG TEX CH18,
Aug 3, 2015
69
ZWOLLE
Even pulling with a chain or heavy strap on the hitch can rear your tractor up and end upside down! I know the ROPS might keep you from getting mashed if you have your seat belt on but don't depend of that 100%. Call someone with a good stump grinder. I lost 5 big pines last year and no way was I able to remove those stumps with any of my tractors. :D
