Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Implements & Attachments
Implements & Attachments Find everything related to operating, servicing and maintaining that loader, mower, blade, snow blower, tiller, hitch or scraper, right here.
Reply
Thread Tools Display Modes
Old 01-31-2020   #21
Creature Meadow
4th Yr. Apprentice
Creature Meadow's Avatar
Equipment: 2012 L4600, 5' Disk, 4' Brush Hog, GB60 Garden Bedder, GSS72 Grading Scraper
Default Re: Comparing Bucket Tooth Attachments
Piranha bar for me had it 4 years never taken it off.
It grabs small trees and rips them roots and all out of the ground.
Does fine when used for leveling and excellent when digging.
If it we stolen today I would have one on the way right away.
Turned my L4600 into a digging machine and like I said does great clearing small trees.
I believe you will like it.
Took me 30 minutes to install and I could remove it in 10 minutes, takes longer to find a socket.
Good luck.
Jay
__________________
You can have it right or you can have it now but you sure can't have it right now!
Creature Meadow is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-16-2020   #22
Terdybukrat
1st Yr. Apprentice
Equipment: B2400, Gehl skidsteer with Kubota v2203 engine, D600 engine
I had a skidsteer and put a ratchet rake on it for specific uses. It worked great for a lot of tasks like clearing & removing brush..., levelling & grading dirt & gravel and was a very useful tool on a 7000lb machine. The way it is used, there is very little extension on the tilt cylinders when it is working so not a lot of force applied to them. While definitely not something i would want on if scooping bucketloads, it is very simple to take on & off. They do offer something i think they call a forestry version that upgrades from straps to cables that i would recommend.
Terdybukrat is offline   Reply With Quote
Old 02-17-2020   #23
shootem604
4th Yr. Apprentice
Equipment: L245DT with Kubota (Arps Model 22) FEL and Kubota B/L4520B (Woods 650) BH
I have a hardpan rock/gravel property beneath a skim coat of poor soil. I got 4 bolt on teeth from Amazon for $40 and drilled my bucket to mount them. They haven't been removed in more than a year. If I want a smoother finish or cleanup up snow I use the blade on the 3Pt. They really help break up the hard ground.
shootem604 is offline   Reply With Quote
Old 02-17-2020   #24
Tim Horton
2nd Yr. Apprentice
Tim Horton's Avatar
Equipment: "PEPE" RTV400
Has anyone used the Piranha for snow on a gravel drive ???
----- Yes.. I got the Piranha bar as to not ware on the bucket edge. There is a definite learning curve on what bucket angle to use it to move snow on the frozen drive, but only takes a short time to learn.. It has worked well..
In fact if anybody has an idea on how to dig in compacted, dry, hard dirt I'd like to hear suggestions.
----- You may have to break things up first with a sub soil shank before trying to dig. I've used this technique with good results.
Tim Horton is offline   Reply With Quote
Old 02-17-2020   #25
RonBoyBX25D
3rd Yr. Apprentice
Equipment: B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
I have both, started with the ratchet rake when I had a ToolCat, works great as mentioned for brush removal, leveling and final grade in prep for seeding. I did about an acre or so at the lake with it. When I downsized to the BX25D I added the Pirahna and it really helped in the digging aspect and also does a decent job of brush removal. I wouldn’t say as good as the RR, but since it is always on it is more convenient. I have since upgraded to a B2650 and it has enough power to rib out the roots of smaller trees, up to about 4”. Again it is always on so more usage. If I had to only have one it would be the Pirahna, fortunately I have both so when needed I can put it on and have a better tool to finish grade and seed bed.
RonBoyBX25D is offline   Reply With Quote
Old 02-18-2020   #26
SidecarFlip
Master Tech
Equipment: M9000HDCC3, M9000HD, Kubota Sidekick RTV,
I have an ATI myself and I bought it with the future in mind. I want replaceable pin on teeth on the bar. Mine replaces with a roll pin, so no welding required and you pay only for the tooth.
__________________
Way too much equipment and not enough time....
SidecarFlip is offline   Reply With Quote
Old 02-19-2020   #27
conropl
2nd Yr. Apprentice
conropl's Avatar
Equipment: L3560 HSDC
Quote:
Originally Posted by GreensvilleJay View Post
yes, has to be removed ! Well, unless you LIKE spending all Spring repairing your driveway AFTER you find the 'missing gravel'....
I don't think anyone has enough talent to NOT grab gravel using bucket/bar.
Edge Tammers can keep the bucket from digging in. Do you think Edge Tammers (https://r2manufacturing.com/products...roduct-reviews) would fit on your bucket with the piranha bar? I saw these used on Tractor Time with Tim... they seemed work well with snow removal.
Sent from my SM-J737V using Tapatalk
__________________
If I can add light to the situation, then I will. If I cannot, then at least I pray that I do not contribute to the darkness.
conropl is offline   Reply With Quote
Old 02-20-2020   #28
tor
1st Yr. Apprentice
tor's Avatar
Using a Piranha bar on my MX5200. Makes a huge difference.
__________________
MX5200 4WD HST / FEL, Woodmaxx WM-8H Hydraulic Chipper, EA 6 ft Hog, Kingkutter 6 ft mower, Howse Disc Harrow, EA Box Scrape, Arien 22 Ton Splitter, Husky 144, 55 Rancher, 372XP
tor is offline   Reply With Quote
Old 02-22-2020   #29
Kevin1
2nd Yr. Apprentice
Equipment: Husqvarna MZT 52, BX2380,FEL, Box blade.
Quote:
Originally Posted by tiktock View Post
All i can say is that I've simply never taken the Pirhana bar off since installed. I agree I can't imagine doing any digging/scooping with the rake as I think its bit more geared around grading gravel and pulling up brush and such?
Same here. Put mine on when I got the tractor and it has never come off. Great piece of gear!
Kevin1 is offline   Reply With Quote
Old 02-22-2020   #30
i7win7
1st Yr. Apprentice
Equipment: root grapel, tree puller, trailer mover, 3 point hoist, mower, tiller
This is how I pull brush and small trees
Click image for larger version
ID:	47319   Click image for larger version
i7win7 is offline   Reply With Quote
Reply
Tags
bucket attachments, digging with fel, piranah, rachet rake
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2020, vBulletin Solutions Inc.
