I made up a couple of tie downs for the rear of my BX, since it may have a couple of trips on my utility trailer in the future. I had my local shop cut and bend the plates 45° for me. I wrote 1/4" on the diagram, but somehow they missed that and made them up in 3/8", so there is no chance they'll ever get bent.
I drilled 1" holes for the eyes and 15mm holes on 70mm centers for using the existing rear holes on the BX frame rails. I replaced the original bolts with 14mm X 45mm - 1.5mm grade 8.8 bolts.
I bead blasted the plates, gave them a coat of self etching primer, and then a couple coats of Kubota Dark Gray.
They look like original equipment!
