B6000 clutch switch?
Aluthin
Kubota B6000
Aug 7, 2015
United Kingdom
Ok I take it this is the switch that stops the tractor being started with out your foot on the clutch. At some time in the past it has been disconnected and bypassed :eek: and from what I can work out its because no matter how you adjust the bolt the switch gets pushed slightly and then the bolt slips past it and then jams against it.
Have looked in the parts list but to no avail and I can't find any mention in the wsm. Does anyone know from the picture whether I am missing a part or whether the switch is the right one?
Thanks in advance
Tooljunkie
May 13, 2014
4,150
27
Some sort of bracket adjustment may help, failing that i would weld a washer to bolt head to prevent it from jamming. Was the first thing i fixed on my L1501.
Aluthin
Kubota B6000
Aug 7, 2015
United Kingdom
Thanks TJ .... I will elongate the hole in the bracket first to allow me to move it over I think...
Can't weld but definitely going to learn too now :eek:
