Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 08-17-2015   #11
Dave_eng
Master Tech
Equipment: M7040, Nuffield 465
Smile Re: M4700DT PTO Shaft seems too Hot
Interesting find with the one cup being hotter.
Now you will start driving yourself nuts with the wealth of data you are going to accumulatehttp://www.orangetractortalks.com/forums/images/icons/icon7.gif
Remember with the heat gun, that the color and type of surface affect a property called emissivity so be certain all cups are clean to get true comparative numbers. If one cup had a smear of dark grease on it it would appear hotter to the gun.
Dave M7040
Dave_eng is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-17-2015   #12
TK4700DT
1st Yr. Apprentice
Equipment: M4700DT, B6100, MF135
Default Re: M4700DT PTO Shaft seems too Hot
My thinking is that the one was setting in a position, before I came along to purchase, taking in more weather than the other.
I will replace both Front and rear.
Thanks for everyone's help!
TK4700DT is offline   Reply With Quote
Old 08-18-2015   #13
TK4700DT
1st Yr. Apprentice
I would never thought this could have been the problem... If I attached the pic hopefully you can see, the yoke bore is actually off center.
Click image for larger version
Old 08-18-2015   #14
VIP Service Tech
North Idaho Wolfman's Avatar
Equipment: L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more
Looks to me like the yoke is bent on the other side?
Regardless of the issue, changing it should help!
__________________
Some days you're being chased by the wolves,
Some days you're running with the pack!
North Idaho Wolfman is offline   Reply With Quote
Old 08-18-2015   #15
Diydave
Journeyman
Equipment: L2202 tractor, L185f tractor
Damage like that could come from shipping, handling, over torquing with a high HP tractor, or just bad QC, at the factory. Them IR thermometers sure is the bee's knees at finding all sorts of problems. Usedta cost around $300, saw an ad last week, for $19!
Diydave is offline   Reply With Quote
Old 08-18-2015   #16
Bulldog
VIP Service Tech
Bulldog's Avatar
Equipment: M 9000 DTC, L 3000 DT
Quote:
I just found one just like that on my batwing. I went to TSC and they didn't even come close to having one big enough so it was off to the driveline shop. After talking to those guys bent or twisted yokes are a very common issue. They said the yoke is one of the first weak links purposely made that way to help save the drive shaft. Like the man said, would you rather spend $50 for a yoke or $300 for a drive shaft.
__________________
AMSOIL, protect your investment.
Bulldog is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2020, vBulletin Solutions Inc.
