Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 03-14-2015   #1
A.O.
2nd Yr. Apprentice
Equipment: L3540HST LA724 FEL
Default Hydraulic quick disconnects??
Ok, I have an L3540 with the smallish Kubota (metric probably) quick disconnects for a end of loader mounted implement (had a WR Long 4 in 1 bucket up there) , anyway, I just traded it for a 4' root grapple that have the American 1/2 inch I believe disconnects on it.
So is it better/easier to change the connections on the loader (my thought) or on the grapple? And am I going to run into a metric to SAE adapter nightmare or will the ones at tractor supply work and how do I tell??
Thanks, I want to get this grapple into service....
A.O. is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-14-2015   #2
Bulldog
VIP Service Tech
Bulldog's Avatar
Equipment: M 9000 DTC, L 3000 DT
Default Re: Hydraulic quick disconnects??
I would compare the cost of just changing the couplers on the grapple and then the cost of changing the tractor side couplers. If the 4 n 1 bucket worked I don't see any reason why the grapple wouldn't work either. Which ever way was cheaper to change that is what I would do. $.02
__________________
AMSOIL, protect your investment.
Bulldog is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2020, vBulletin Solutions Inc.
