Is Steering cylinder TA040-37803 rebuildable?
kubitvf
Sanford NC
I have a L2900DT and steering cylinder part No TA040-37803 is leaking. Is this part rebuildable or is only choice to purchase this part for 800.00? Any help appreciated.
Tooljunkie
May 13, 2014
4,150
27
Usually if they can be disassembled, they can be repaired.
Used to send green ones to a machine shop, welded assembly. He would cut the cylinder apart and rebuild them. Funny, they never leaked after he rebuilt them.
Apogee
Jan 22, 2012
518
Tacoma, WA
Go to kubota.com, "Parts" at top of screen, choose "Illustrated Parts List", accept the agreement, and plug your model of tractor in. You will then have all the part numbers at your disposal. They are listed under "Steering Cylinder Component Parts".
Good luck,
Steve
Jack Lithgoe
L2900, 4wd,FEL,Tiller, Brush cutter, grader box
Feb 18, 2019
Baton Rouge, LA
Based on the illustrated parts list, I would say yes.
MDHughes, You responded to this question a few years ago. I have a similar question. The illustration shows the parts that make up the steering cylinder for a gang of Kubota tractors. Mine is a L2900DT 4wd. I also found it in the parts manual (pdf). Can you tell how to get a complete seal repacking kit that includes all of the sealing parts? Your help is appreciated.
Thanks,
Jack Lithgoe
whitetiger
Nov 20, 2011
2,582
1,101
Kansas City, KS
Thanks,
Jack Lithgoe
There is no seal kit, you must order the seals individually.
