Found this spring under my B3300SU
Dpop24
B7800
Apr 7, 2013
10
Grass Valley, CA, USA
It's now getting dark so thought I'd be lazy and ask you guys instead of crawling around under my tractor in the dark. Anyone know what this is?
Tooljunkie
May 13, 2014
4,150
27
Anything not working correctly? Thats probably why. The spring wore through and broke, next fell off. Where it goes, i dont know,i would have to say best is to look under and see. To replace it from dealer you need to know what it does. The parts guy cant be expected to know where it goes either.
4,365
Maybe you have a mower that has an idler pulley to keep the belt tight? This spring may go to it.
Maybe it belongs to your neighbor and you just happen to find it!
Dpop24
B7800
Apr 7, 2013
10
Sorry.... Yes, clearly it is broken. Stupid question time: how will I know where it came from if it's missing?
I didn't actually run it today, I just happened to be walking by and saw it under the tractor.
Olthumpa - too funny on stretching the buck!
2,162
My first thought too ^^^^^^ idler pulley off a MMM?
4,365
Since we're playing a game of clue, do you have a mower setting under your tractor?
If yes, look for the pulley that keeps the belt tight. See if it has a spring attached. Feel the belt to see if it seems real loose. OH, WARNING-- do not do this while the mower is being powered.
4,365
85Hokie, since the OP is new to the forum, ask a question that he knows is call for "stupid question time", then disappears as he's getting answers---is probably playing games with us!!
Dpop24
B7800
Apr 7, 2013
10
Well, you guys got me crawling around in the dirt with a flashlight looking under the tractor. [emoji2]
My mower is parked 100 yards away and hasn't been run since last summer, so I'm confident it doesn't belong to the mower.
As I suspected, it's a lot harder to see what is there than what isn't there but I ran it for a minute to test some basic controls: all hydraulics work (duh?). The brake returns correctly and has a spring in place similar to this.
I'll try to swing by the dealer and see if they have an idea and will run the tractor through some paces to see what's not working.
Dpop24
B7800
Apr 7, 2013
10
As for the stupid questions, it's due to this being my first tractor. Only got 38 hours on it..... I'm a newbie to the forum as well as a newbie to tractors.
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
272
133
catlettsburg, ky
:mad:
Well, that link didn't work.
It looks like that spring should be, about, under your right foot.:)
Dpop24
B7800
Apr 7, 2013
10
Link didn't work but I'm trying to look on kubota.com without any luck so far. Sounds about right on the location. It was on the right side, smack dab in the middle between the wheels. It's not the brake pedal return spring though, I've confirmed that's still there.
ibunker
B3300SU w/BK76, Box blade, DR wood chipper
Dec 5, 2010
52
Port Orchard, WA
It's from the top clutch bracket just above the zerk fitting leading to an 1 1/2 x 12 inch angle that runs side to side. I just repaired this angle as it broke and had to weld it to repair. Have fun reattaching it, it's a bear to do. And thank you, for I was under my B3300su tonight with a flashlight.;)
Dpop24
B7800
Apr 7, 2013
10
Thanks ibunker for crawling around under your tractor with a flashlight. That's what I all going the extra mile to help a guy out! I'll get a good look under there tomorrow and see if I can find where it should go.
2,796
Dpop please remember there are NO DUMB QUESTIONS HERE, some dumb answers maybe. Remember there is always somebody in here that has BTDT and can give an answer, sometimes it takes a couple days other times bang you got it right now... Oh and please don't forget we love tractor porn too:D
ShaunBlake
Dec 21, 2014
899
Hey, if I didn't pipe up with my dumb answers, what would you do for a lowest common denominator?
And Dpop, don't believe him! There is one, and only one, dumb question: the question that doesn't get asked!
