Smallest tractor with hydro "Top n Tilt" ?
miketrock
163
Pa
Can hydro Top n Tilt be put on a B2601 with parts from other kubotas ? Without going completely custom fabbed ? On a B2601, you can get 2 rear remote valves, but Top n Tilt isnt offered.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,127
933
Williamstown Ontario Canada
Top and tilt is installed by just plugging into existing rear remotes.
Apart from the "top and tilt" cylinders, hoses, & couplers, nothing else is needed
Dave
miketrock
163
Pa
I just went on kubotausa.com and saw that there's a Top n Tilt kit for an L2501 tractor. Can that Top n Tilt kit for the L2501 tractor be used on a B2601 ? Why start from scratch if its already engineered …. maybe just plug n play …?...
MtnViewRanch
719
176
Lakeside Ca.
the L2501 parts will not fit, the B2601 has a totally different 3 point linkage style. there is a fellow on the site that builds kits for your tractor, the fabrication and engineering is second to none.
https://www.fitritehydraulics.com/
Thanks for the compliment. ;)
As mentioned, completely different.
1st pic is for a B series.
2nd pic is for std size L series such as the L2501 that was mentioned, up to an L3901.
Different top link strokes, different ends on both the top & side links.
