Jrh
L185, Woods Finish mower, 1 row cultivator, 1 bottom breaking plow, 1 shank rip
During the process of removing the front cover to check and replace the missing front camshaft oil plug the water pipe that goes from the cover to the block broke into leaving about 1/4 " of pipe still in the block. How does a guy go about trying to remove the piece? Tried yesterday to saw a slot in the bottom of the ring and pry the sides loose but so far did not work. Is there some trick to removing this piece? Maybe heat the piece of ring? Is there a tool made that will expand in the hole and grab the sides of the ring to back ring out.
Thanks for any help
jrh
[/ATTACH]
Thanks for any help
jrh
[/ATTACH]
