SSQA pin adjustment
mdhughes
L3901DT
Dec 10, 2014
1,449
1,478
Ste Geneveive county, MO
The left pin (as looking at the tractor) doesn't retract all the way. So I looked in the LA525 WorkShop manual for the correct adjustments for the springs and adjusted both sides. I also cleaned the pins and the tubs that they are in. Greesed both of them and still the left pin doesn't retract all the way. I have taken all kinds of measurements to compare one side to the other and I can find anything that is different. You can see in the top picture that the pin is sticking out, but on the bottom picture (the other side), you can't see the pin. Has anyone else had this problem? I don't remember if it has always been this way or not.
2,911
One thing I noticed is the springs (over the threaded bars) appear different. The second picture looks more compressed (wire is closer to each other).
What happens if you tighten the nut in the second picture?
mdhughes
L3901DT
Dec 10, 2014
1,449
1,478
The springs are both set the the length that the WorkShop Manual specifies.
2,911
But what happens if you tighten the nut on the incorrect side? It should pull that tang back (as I see it)?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,196
2,860
Near Lancaster, PA, USA
If the pins allow removal of the implements when raised and drop down enough to be fully engaged when lowered, don't worry.
7,514
I'd back that lock nut off a bit on the side that doesn't engage as far. That forces the rod to push the pin. the spring only helps to keep it all in place.
Dagman
Bx23s
Apr 16, 2026
Quebec
Exact same thing on our new Bx23s. It was actually resulting in difficulty when putting on and taking off attachments. Not being well versed in tractors I blamed myself. I have had a degree of success after tightening that lower nut that angles up at 45 degrees. The pin still sticks out more than the other side does but it seems to be good enough.
Curious to know what you finally did. There is one Youtube vid of a guy who does not mention adjusting the nut like I did, but shows a way to grind the arm contact point to help. Just don't want to start grinding a new tractor on day two. I normally wait at least three days before I start making stupid mistakes!
mdhughes
L3901DT
Dec 10, 2014
1,449
1,478
I haven't done anything else to it yet. Now that it is getting warmer I will look into it again and if I find anything I will do a follow up post here.
10,700
Yep just need to make the handles open further.
Old Machinist
May 27, 2024
638
747
NE FL
Never looked at my pin engagement since it seems to work but now that I am looking at these photos I realize I need to tighten the pivot nuts on mine. My handles will sag after running with no bucket and I have to pull them back up to attach anything.
6,944
What needs to be shorter? If you are talking about one of the springs, they are set to what the workshop manual has.
I think that something didn't get welded right and that is what is causing the problem.
I am talking about the spring. Crank the adjuster nut dow.n 1/4 " and watch whst happens to that protruding tip.
Da n
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
373
284
NH
Maybe I missed it, but did you check to see if something was binding up, preventing it from fully engaging?
mdhughes
L3901DT
Dec 10, 2014
1,449
1,478
Da n
It doesn't make the pin come up as you would think. I spent a lot of time working on this and adjusted to the specs in the manual. As I said in my reply to you, there is something not welded right on that side of the SSQA and it is making it not pull the pin up all the way.
10,700
Did you watch this video, it explains exactly how to fix your issue.
6,944
I dont know what is out but you just need a little more travel. See post #17 and the video posted by NIW.
