M6950, 3 point and PTO drive issues
that7.5
M6950, L2350
Nov 2, 2025
Teague tx
So I can't say for sure what year this tractor is they made em from 83-93 I believe ours is a 90s, but on point, the 3 point sorta works after I bled the hydraulic lines but the PTO won't engage it's not the exterior linkage, I was able to test it it was engaging on the interior by spinning the shaft from the rear and when it was disengaged it spun fine and vice versa, now here's the twist occasionally the PTO will work but as soon as it will engage the 3 point quits working, I don't believe the hydraulic pump is falling because, the power steering works fine plus I was able to bleed the lines pointing to the fact that the pump is working but I guess theoretically it could just be weak, but that doesn't explain the whole PTO issue, but I know that the PTO drive works of the hydraulics, the rear end fluid was changed recently (rear end, trans and the hydraulics run off the fluid in the rear end) but this issue was there before hand, also there is a large amount of vibration from the hydraulic pressure line that runs from the pump to the rear end, Any help would be appreciated.
2,402
You need to be more specific on which model you have. There are several and they might have a separate pump for power steering from other hydraulic systems.
But the vibrations in the pump output lines seems like that could be a pump problem.
that7.5
M6950, L2350
Nov 2, 2025
Teague tx
I know very little about this tractor however I do know it is a M6950 71HP 4.0 L, four-cylinder, liquid-cooled Kubota V4300-2A diesel. I'm unsure of the year but like I said I do believe it to be 1990s+ year model.
2,402
Going to the illustrated parts list at this site
and searching for M6950 you get these results so you may be able to eliminate some. The biggest differences may be in the synchro shift version versus the others so hopefully you know the differences in how it shifts OR there may be a label on the tractor that shows the model and serial number.
that7.5
M6950, L2350
Nov 2, 2025
Teague tx
It's a 2wd W/ rops only, it's a 16 speed (1,2,3,R-A,B,C,D range) its not a GST.
9,328
There is no GST option in that model.
Need the serial number if you can't answer if it's a M6950 ar a M6950-S
Sounds like you have a suction issue.
that7.5
M6950, L2350
Nov 2, 2025
Teague tx
I'm having a hard time finding the serial number alone even harder time to figure out how to decode the non-17 digit number, I read that on the m5950 you can find the number stamped on the front end of the trans, I've found number stamped on the front of the trans and rear end, but nowhere can I seem to find a stamp or sticker on the frame. What's the difference between the M6950 and the M6950-S ?
that7.5
M6950, L2350
Nov 2, 2025
Teague tx
that7.5
M6950, L2350
Nov 2, 2025
Teague tx
*M6950* (typo)
9,328
The M6950-S is shuttle shift, parts will be different, and testing might be different.
Look at this dipstick detail to be able to tell which model you have.
This is a M6950
This is a M6950-S
9,328
I would start by checking the suction side of the hydraulic system.
Look for wet spots.
that7.5
M6950, L2350
Nov 2, 2025
Teague tx
Look for wet spots.
I didn't even see your reply lol, but after digging into it I've traced everything to the hydraulic pump or like you said a leak in the suction lines, the pump seems to work fine then when running the pto using my hog, at random times it seems like the pump just loses prime and fills the system with air, the 3point quits and the PTO sticks on regardless if it's engaged or not I can disengage it via the lever but not the switch on the console, I can't find a leak in the suction lines but obviously that doesn't mean it's not leaking, im hoping it's not an internal problem with the pump I don't want to spend however much W/O making sure it's not a leak.
