Looking to find a L47TLB diagnostic cable
Harley Monster
L47 Backhoe,Loader, Forks, Top&Tilt, scraper box, rake
May 9, 2011
20
Temecula, CA
I am looking to find a L47TLB diagnostic cable, my tractor is a 2016 model. I have located the tractors diagnostic cable connector, it has the proper colored wires going to it as shown on the Main ECU schematic, but the diagnostic cable I have, the 382426 has a different connector and will not mate with the tractor. I know the L47TLB is marketed in Kubota's Construction Equipment Division, but I am surprised the diagnostic cable would be different. If I can't find a premade cable I would like to find the connector that matches the tractor's. I have 3 382426 cables so it would be easy to convert one of my cables. I have all the pin outs for the connectors.
Are there any Kubota techs on this forum who could help me? Either I could get the premade cable or the proper connector. I have a DST-1 and software I would like to connect to the tractor.
9,355
Is this the cable your looking for?
And good luck reading and writing anything to the ECU.
Harley Monster
May 9, 2011
20
Temecula, CA
Wolfman,
This is my problem, I have 3 of those cables, in fact I purchased the exact one you linked, but the check connector on my tractor is a different connector. MY tractor's connector that I found to the right of the steering column has the proper 4 color coded wires, but this 382426 does not plug into the tractor's check connector. Unless there is a second 4 pin connector with the proper color coded wires this cable is not the correct one for my tractor. I have the WSM for the tractor, the WSM for the V2403-CR-E4 engine and now I am looking for this engines Diagnostic Manual.
Please explain your good luck comment.
Vlach7
L47 305DT JD500C
Dec 16, 2021
399
279
Frazier Park Ca
Please keep me/us updated, I am sure I will eventually be in the same boat. I got mine used in San Diego 5 years ago, had 330hrs, now has 750hrs.
