Building My Own Replacement Instrument Cluster for the BX Series
Jason Sewell
BX2370
Aug 3, 2025
Midlothian, VA, US
This thread may only be of interest to people who 1) Own a BX-series, 2) Have suffered repeated instrument cluster failure due to water intrusion, and 3) Are interested in embedded system development. But hey, maybe there is more than one of us!
After replacing my gauge cluster twice at ~$500 a pop, it has once again died due to moisture getting into the electronics. The most recent death struck the supposed "re-engineered" panel. So I decided it might be fun to make my own replacement.
The project is only about halfway complete, but there are enough bones that anyone interested can follow along and maybe even make contributions. I'm using an ESP32 microcontroller and a few assorted discrete components to turn the signals from the wiring harness into output on an CD panel. I started with a very nice, sunlight readable panel, but I accidentally destroyed it in a soldering mishap, so I switched to a cheaper TFT color panel for now.
The project is hosted at hackaday.io and GitHub. Feel free to take a look, ask questions, and make a pull request or two if the mood strikes you.
Here are a couple of pictures of the water damage in the gauge cluster.
You can see that some of the header pins are completely corroded away:
I am looking for a way to reuse the stock pan if possible.
My "workshop"
A prototype of the user interface:
Bonebeard
BX25D, Box grader, Snow blower, Back hoe, Finish mower, Front forks, 48" Tiller
Oct 16, 2022
Manitoba Canada
My "workshop"
Hello sir, did you ever get this installed in your tractor?
6,243
NICE...love to see real hackers making things !! I settled on PICs 25 years ago,and well, too old to 'upgrade'.
FWIW ..the water 'problem'. drill 5 or so SMALL holes ( #63 , IC pin size) both top and bottom of the cluster to allow air IN and OUT. it should help !
Mowbizz
Bx25d
Aug 19, 2021
599
349
Dealer replaced my first one under warranty but soon after the new one started getting moisture inside as well. All gauges still work however!
I should try the “holes hack” 😊
John T
2017 BX23S
May 5, 2017
1,248
779
under a rock
Pretty cool.
Curious, What year is your BX?
I've only had a problem with my 4 way flasher switch. disassembly/silicone grease fixed it.
Also, tech question.... what is the best soldering iron/gun to solder connections on a green printed circuit board like that?
My 1972 pencil soldering iron takes 3 days to heat up and the bigger gun is too cumbersome to maneuver
Hugo Habicht
G1900
Jun 24, 2024
1,506
2,159
Ireland
The water comes in the top but cannot get out due to the bathtub design. I would only seal the top properly, drill small holes at the bottom, give the board a lick of conformal coating and apply vaseline to the contacts.
Hugo Habicht
G1900
Jun 24, 2024
1,506
2,159
Ireland
My recommendation would be Weller WTCP or WECP with a short and wide tip (No. 7 temperature for the WTCP). Thin tips can never have enough heat flow. Those soldering irons are made to last and there are plenty available second hand for very little money.
Grandad4
Apr 5, 2016
420
178
Greensboro, NC
Nice project! But gotta wonder what is the source of all that moisture. Any way to find/create a dryer place to park your BX?
G.Dawson
bx2350 b5200
Mar 20, 2026
NY
Any updates here? Ive got a bx2350 whose tach / hour meter only works when its hot, better if its direct sun. wondering if I can fix this LCD, at least as good as a half dead calculator, I'm willing to make an educated guess about hours, not so much when I'm doing trig lol
G.Dawson
bx2350 b5200
Mar 20, 2026
NY
Ive got an 80's wheel loader that looks like it was parked under a pier for its entire life, all its gauges work great, it does have a tin locking vandal shield, but its certainly not weatherproof. its a little disappointing that after 20 years of bx development Kubota is still dropping the ball on the weatherproofing the dash. not like every modern motorcycle in the universe does not have a viable solution that will handle driving through the rain at 80 miles per hour.
