BX lift pump issues.
farmerNick
Bx2380
May 30, 2025
SEMO
Welp, the 3rd lift pump is now doing what the 1st two did...stops working after about 5-10 mins of work. Work = just driving.
1st Lift pump quit intermittently.
I have removed the in line filters. I installed a larger inline, water separator type bulb filter. Installed 2nd new lift pump. Took about 30mins of work before it happened again... SO, No changes. (I'll put another in-line before the lift pump, after I solve this issue.)
I installed a 5" cleanout/access in the top center of the tank. Siphoned empty. Dried, and vacuumed inside the tank. Installed a screen around fuel port. Also added strainer to fuel fill opening. Tank is clean. Installed 3rd new lif pump. Worked for about 20 mins. So, Still no change.
What is killing these lift pumps? Or is it that they are Chinese crap?
2,825
I think you nailed it on the head with your last statement
5,647
Heck my BX23S ran for weeks without a lift pump.... only noticed the connector off of it when I crawled under to see 'something'. Saw the connector unplugged, reattached it and naturally forgot WHY I was under in the first place.
If Kubota pumps ,from Kubota.... I'd go back and ask. A good dealer WILL refund/replace AND look into WHY you have THREE bad ones.
farmerNick
Bx2380
May 30, 2025
SEMO
How is that possible? The fuel line would be separated.
Fedup
301
107
Winchester
You're buying the$12 pump online? They're only good for twenty minutes.
TimAT
GF1800 4x4 60" Mower
Oct 5, 2023
40
Kansas City. MO
I went thru a batch of the $20 lift pumps too. Went with an OEM pump and was still having problems. Intermittent loss of power, never did totally quit, just power would fall off and run rough, then it would come back and be fine. Ended up pulling the tank, flushing it, and then found the pickup tube was nearly plugged with some goo. I assume it was algae. Scrubbed it out with a gun brush. replaced all the rubber lines, and no more problems. (so far)
BX'r
BX2370
Jun 13, 2020
105
22
Sault Ste. Marie, Ontario, Canada
What did you find in the tank?
