I recently purchased a low-hour BX1880 that came with a LA344. Two previous owners; guy I got it from only had it for a few months as it was way too small for his needs. The original owner replaced the FEL side single-point-connector (SPC) with the individual connectors as a preventative measure. Well, after the individual connectors were installed it had formed a leak. The guy I bought it from said it has slowly leaked the entire time he had it (last few months) and he always just topped off the fluid. Well this doesn't play well with me. I reinstalled the loader side SPC and saw that it was still leaking. On the tractor side SPC I used a tool to push down the center of and I saw a single orange seal. I pulled the seals out using a cheapo HFT pick tool and noticed they were all clean and unremarkable. I cleaned it up and reinstalled all four seals. Voila! No more leaks. It is difficult to find out where I can purchase replacement seals. It appears that the John Deere SPC use "MultiFaster" SK-MF-38 / AXE61023 (3/8") seals (Italian). They look very similar and are about $10 each. Has anyone replaced these seals before and if so, do you have a part number? The seals have square corners and the bottom of the seal has a small trough (probably to allow for compression). The photo I posted is showing the bottom of the seal facing up.
