Transmission Oil Sight Glass
Jsinus
L3800
Aug 15, 2021
15
California
I've a Kubota L3800 HST and need to replace the Sight Glass. Do I need to completely drain the Transmission Hydraulic oil b4 removing the glass ?
JasonW
474
253
Al
No not completely. Just drain just below the sight glass. Or if you’re comfortable have a drain pan ready and remove the old sight glass and install the new one.
old and tired
L2800 HST; 2005; R4
You can run it up on a side hill until the oil is below the sight glass, no hill, use a jack to artificially make one!!
depending on how low it is, you might be able to use the FEL to raise the front up enough to switch it out...
Flintknapper
L2350DT
May 3, 2022
1,929
2,434
Deep East Texas
This. I just drove my tractor up a ramp on one side, then replaced the sight glass.
