Would it be a fatal flaw to order a new Kubota without the rear hydraulic coupler option ? Runs an extra $850, don't think I'll need it, but don't want to limit resale opportunities. Wallet vs. common sense ?
Can you please let us all know where you can get a 3 spool valve,(2 should have the float function and 1 either detent or just spring return to center) power beyond ready, 3 sets of female QDs and all the rest of the plumbing for $400.Do not waste your time or money going through the dealer for rear hydraulics.
I have an L3800 and will be doing both a 3rd valve for the grapple bucket up front, plus I will be adding a 3 valve setup on the back of the tractor for TnT and the 3rd valve will be detent, which keeps the valve open so that it can be used as either side shift, or hydro "PTO".
You can add a 3 valve setup to the rear of your tractor for UNDER $400
See this thread on why you'd want 3 valves at the back.
http://www.tractorbynet.com/forums/...g/208593-top-tilt-rear-remotes-installed.html
Get at least one with the float function, both if at all possible. There are situations and circumstances where it is nice to be able to put hydraulics into the float position.Eric and Mtn View, am going with the remotes (2) second remote only an extra $240.
Dealer however asks for a choice for second valve...DOUBLE ACTIVE VALVE or FLOAT DETENT VALVE. I am WAY over my head on this, but want to be able to do grading plus farm chores. Ech year I move 160 yards of compost to low areas and rake, back blade or roll in an attempt to grade. Passable, but not great. Will sell my trusty L2250 4wd FEL to upgrade to a single tractor.
Help appreciated and welcomed.
So the valve with 2 float functions is $303. You can get 3 hoses and 6 female QDs with all the other fittings needed for $97? And of course shipping is apparently free?3 Spool valve good for 8GPM $238.95 (would need larger if you went with a tractor that has a hydro flow above 8GPM. My 3800 has less so I'm good)
https://www.surpluscenter.com/item.asp?item=9-7863&catname=hydraulic
Adding detents is $31.95/ea. They are out of stock on them currently, but it's the first time I've seen this.
https://www.surpluscenter.com/item.asp?item=9-7867-D&catname=hydraulic
You'd need less than $100 in hoses/fittings to finish the job.
I'm going to mount to the rops in the rear. The valve allows handles to point up or out.
To mount, you'd need to fab a steel plate to bolt to the rops with U bolts. (see this post http://www.tractorbynet.com/forums/...g/208593-top-tilt-rear-remotes-installed.html )
He installed valve on the front, I'm going to put it in the back where the ROPs goes vertical. Allows operation on and off tractor.
I'm going to use this setup for TnT, plus a side shift (w/ detent) to use as hydro PTO for using a log splitter or whatever is needed in the future.
Odd, I'm not going to use QCs for my TnT, but yes, all fittings, hoses, and QCs came out to $100 including 6 sets of QCs(6F, 6M), not including shipping (I'd be surprised if it's more than $20)So the valve with 2 float functions is $303. You can get 3 hoses and 6 female QDs with all the other fittings needed for $97? And of course shipping is apparently free?
You are a much better shopper than me, that or we just don't shop for the same things.
I know the difference between a detented 3 position valve and a 4 position valve that has a detented float position.Odd, I'm not going to use QCs for my TnT, but yes, all fittings, hoses, and QCs came out to $100 including 6 sets of QCs(6F, 6M), not including shipping (I'd be surprised if it's more than $20)
I don't need $24 worth of QCs, nor the extra detent add-on so I'm under $350.
Are you confusing float with detent? They are not the same thing.
This also does not include the plastic covers for the QCs, but they're not needed to make it function, and they're about $1 each.
