Hi, I have a Kubota L 2050 that blows off water out the radiator overflow when I'm mowing with a 6' wide finish mower. The coolant level is just above the radiator fins when it does this. The RPM that the motor is running out is about 2,200 or so not excessive by any means. The motor runs fine and doesn't appear to be lugging down. Last night I sprayed out the fins of the radiator with a garden hose. Do you have any suggestions and do you think the motor is even over heating? or could it be a bad radiator cap that isn't holding pressure??? Thanks for your insights
