LA535 lift capacity at front lip?
mrrlyoung
LX2610HSD, LA535 loader, BH77 backhoe, LX2963 snowblower
Jul 16, 2023
34
10
California
What would be a safe lifting capacity for something hanging on a chain (or chains) which are hooked over the cutting edge lip of a LA535 FEL on a LX2610?
4,897
according to online info....
No code has to be inserted here.
500mm =+-20".
so I'd guess 500#s
Hopefully someone with an LX2610 can reply with 'real world' knowledge !
Moose7060
Oct 14, 2023
506
1,133
bc
I use forks but was told a long time ago if using chains on a bucket the strongest way to do it is hook onto the lip of the bucket in line with the loader arms and run them underneath and over the back of the bucket and then down to what you are lifting. Always use two and yes it does require longer chains than straight from the lip.
mrrlyoung
Jul 16, 2023
34
10
California
I need to pick up our snowblower and move it around from time to time. I've used chains over the loader arms and in other configurations. I don't want to bend the bucket edge, so I have avoided chains hooked simply to the cutting edge. But I was curious. I do have longer chains that are probably long enough to arrange as you mentioned. I like the fact that you still get whatever height advantage you might get attaching directly to the cutting edge, even though the chains wrap around the bucket. But I guess I still wonder about the lift capacity since the load is not in the bucket but at the maximum distance away from the tractor.
5,546
If you want an answer put the chains around the bucket as Moose described and pick up your implement. It either does or doesn't. If the rear seems too light add something to the back. Never lift any higher then necessary, and only do the highest lift when necessary and drop back down.
4,469
If you run the chain behind the bucket you are lifting at (very close to) the pins.
3,545
2,001
Nothing...there is no "safe" lifting capacity of a device not made to safely lift things.
Safety device like lifting chains require a certified load capacity tag.
mrrlyoung
Jul 16, 2023
34
10
California
"It either does or doesn't "
Ah, yes. I forgot the tractor has some hydraulics overload protection, not that I want to run too frequently or for too long near that limit.
Sidekick
Jul 29, 2023
553
496
N.Y,
You could just pop the bucket off and chain to the quick connect plates. Then you have over 250 extra pounds of lift capacity.
mrrlyoung
Jul 16, 2023
34
10
California
Thanks. Good tip if I have to lift something heavier than our blower and I want to increase the lift capacity.
