Want a new tractor. Looking for suggestions.
rc51stierhoff
3,069
I have a BX2380 and use it some almost daily. If something happened to it I'd get a current version in a heartbeat to replace it. I use it to mow the lawn and haul stuff in the dump trailer.
I also have an old (55+ years) utility tractor that has seen better days. If I replace it I need something for mowing my 14 acres of fields and doing some other work where I need a front loader.
Any suggestions? Should I stick with another Kubota or get some other make?
Thanks.
Good day.
Depending on how long you want it to take to mow and how much you want to spend (those two may not match) that might help suggest some options. I think from what others have said you have some good info already, but if more specific on your criteria may get some other responses (maybe).
How long do you want it to take when you mow? Without that piece of info there is a pretty big range of options that will do what you are asking.
Is there a price cap?
I think after asking those two questions maybe find where they collide or come closest to each other. (If you have a lift capacity in mind that would be helpful to narrow down choices as well)
Good luck. 👍
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,111
1,225
Near Lancaster, PA, USA
Thanks for clarifying!
Is a 3-point carry box another name for a carry all? I'd love to have one of those for carrying bags of mulch, fertilizer, potted plants, etc. My wife wanted the dump trailer we have but it's cumbersome when I have to lift everything over the sides.
There are lots of examples on the board. Here's a thread on the one I built:
pgmrdan
BX2380, L3902HST, Massey Harris Pony, Ford 3000, Bobcat 751 skid steer
Aug 16, 2017
201
80
Thanks chim!
Grandad4
Apr 5, 2016
323
79
Greensboro, NC
Sound advice here, IMHO. Would only add that in a similar situation I ended up keeping - and using - both a BX and a much larger Grand L. Each had its jobs to do where the small or large size was very useful. If your budget and your space permit, that's a really good combination.
pgmrdan
Aug 16, 2017
201
80
That's my plan!
Thanks.-
BBFarmer
L3560HSTC-LE, L3301
Jul 12, 2024
36
66
Southeastern MS
Can't go wrong with the Grand L. Got no complaints with ours.
I cut around 14 acres as well. With 6 feet of mower at 3.5mph it takes quite a few frosty beverages to get through it. And the ground is a bit too bumpy to go any faster because of said beverages lol.
mcmxi
6,286
NW Montana
Wow! You can cut at 3.5mph? I'm lucky to get over 2mph with a 12ft folding cutter, 7ft rotary cutter or 5ft flail. I guess you're not cutting stuff that's very tall or on a property that's hilly. The photo taken at my friend's place this past summer gives the impression that the ground is smooth but it's not.
Bearcatrp
Mar 28, 2023
618
334
Minnesota
Would like to see the field you cut after a few frosty beverages. Can imagine a figure 8
Grandad4
Apr 5, 2016
323
79
Greensboro, NC
Just bring along more frosty beverages next time. You'll think that field is smooth as velvet. 😀
pgmrdan
Aug 16, 2017
201
80
Talked to the Kubota dealership salesman yesterday and he gave me brochures on a few tractors he recommended for my needs. He dropped by today to look over my old equipment so he can make an offer.
Still picking out what I want.
I think another Kubota is the right choice.
mcmxi
6,286
NW Montana
So it isn't just the field that's getting buzzed! 😂
pgmrdan
Aug 16, 2017
201
80
The salesman gave me some print outs and brochures on 3 new tractors he has in stock that will do the job. These are all for a 6' mower and front loader.
L3902HST
L4060HST-LE (correction: no cab)
MX5400HST
I might go back and look at them later this morning. I could order something different and wait.
What do you guys think?
Bmyers
May 27, 2019
3,293
3,849
Southern Illinois
For my comfort level and if I was mowing 14 acres, I would want a cab. That is just me.
Moose7060
Oct 14, 2023
504
1,132
bc
L3902HST
L4060HST-LE (with a cab)
MX5400HST
I bought a new L3902HST a few months back just for running my 6" mower. Couldn't be happier and the spousal unit enjoys running it as the HST makes it easy for her.
Little Timmy
Kubota Grand L5460
Aug 21, 2024
40
Wyoming
I think if you stick with Kubota you'll be doing much better than say a John Deere :ROFLMAO:.
They used to be looked up at years ago, and I always used to drink the green Kool Aid. But when I sold my JD zero turn mower, I went with a Wright Stander and happy with my decision. And when I sold my JD 2950 I went with a Kubota Grand L5460 and don't regret not going green one little bit.
mcmxi
6,286
NW Montana
I've owned two open station tractors and two cabbed tractors and I would agree with you re the cab.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
136
136
I've owned 4 JD products over the last 30 years. 3 of them have been reliable and trouble free. The last one had so many quirks and issues that I traded it in on a Kubota and haven't looked back.
JD seems to be having a lot of poor building issues from the factory according to JD forums.
I will not have another JD.
pgmrdan
Aug 16, 2017
201
80
Which one and why: MX5400HST or L4060HST-LE?
BBFarmer
L3560HSTC-LE, L3301
Jul 12, 2024
36
66
Southeastern MS
Lol, Luckily its all blueberry rows which do end up becoming more like lanes after a few.... it helps.
PaulL
2,431
1,361
NZ
I'd buy the L4060. The Grand-L is a more luxury machine, flash transmission, lots of more luxury features. Cab is a good idea, depending on your climate. But it's not really about me.
For your specific use, an MX is probably better. More tractor, bigger cutter on the back.
Both of them will do the job. The MX will do it a bit faster and with a bit more power. The Grand-L will do it with more comfort but a bit slower.
