Help! Bought a used DR Power equipment leaf vacuum and it didn’t come with the tow hitch plate. Even if it did, I have a 3 point hitch installed and I think I’d need to remove that to use the standard hitch, which isn’t ideal.
Conceptually I know what I need (a plate which uses the receiver on the 3 point hitch) but I cannot find one/work out what to search for.
Does this exist? Should I be using something else?
Picture shows the vacuum resting on the hitch. There is a hole where I could use a pin, but does not seem strong enough.
Thanks!
Thanks!
