L2350DT D1102-AE-2 injector rebuild
DrakeRemoray
L2350DT
Jun 24, 2024
58
Alvarado TX
Are the copper washers #30 a standard size? Can I get them off the shelf from (don’t kill me) harbor freight copper washer pack?
Also, do I need to replace #50 washers?
And for the life of me…I’m not seeing a #60 in my injector or I don’t know what I am looking at?
DrakeRemoray
L2350DT
Jun 24, 2024
58
Alvarado TX
Well the #60 adjusting washers that were left in the sonic cleaner are a bit chewed up from the solution….looks like corrosion around the outside edge. I have one good one that made it out of the cleaner and 2 bad ones. Any chance I can manufacture my own? They seem to be just steel and I can get the diameter and the thickness off the good one and make one….or am I stupid and should just order and wait 6-7 days to get the part in?
Flintknapper
L2350DT
May 3, 2022
1,764
2,216
Deep East Texas
Order the parts. Do it right....be done with it.
Also, please take pics and document your injector rebuild here. I have the same engine and might need to do this some day. ;)
6,350
You really should send your injectors in and have them professionally rebuilt.
It's a lot more complicated than it looks to get the to flow and pop properly.
DrakeRemoray
L2350DT
Jun 24, 2024
58
Alvarado TX
I have no doubt in the wisdom that you give out! A quick search of any question on the forum and you are quick to respond with accurate diagnosis!
So please humor my question! The injector looks to be incredibly simple with a spring a shim and the plunger/fuel pin. I am not seeing any adjustments that could be made and if just disassembled cleaned and then put back together…what adjustments/parameters could I have accidentally changed?
Plan will be to put them back together as parts have been ordered and then if they don’t work…send them in. I would like to learn how to properly diagnose and adjust a fuel injector….I just really enjoy learning and buying tools!!! 😁
6,350
What "wears"
Is the nozzle and the spring.
The spring being weak will change the pop timing and pressure, which changes the amount of fuel delivered and the time at which it's delivered.
To test it properly you would need a spray test rig, which is a pump and a pressure gauge to measure when it pops.
They adjust the timing and pressure with different thicknesses of the adjusting washer and different spring tensions.
DrakeRemoray
L2350DT
Jun 24, 2024
58
Alvarado TX
What "wears"
See this is why I asked! Fantastic information! Thank you sir!
DrakeRemoray
L2350DT
Jun 24, 2024
58
Alvarado TX
Well, I rigged up the injector lines and tested the injectors before I cranked them down after the cleaning and rebuild….glad I didn’t just throw them in!
I have one that needs to be taken back apart and inspected.
Really neat being able to watch them fire! I have pretty good spray patterns on the other 2. I took slow mow video which really helped seeing the patterns.
I’ll take apart the one that’s missing and see if it possibly got blocked.
2,919
1,380
What pressure do you have them set to pop off at? It is equally as important as the spray pattern.
DrakeRemoray
L2350DT
Jun 24, 2024
58
Alvarado TX
Well there’s the problem right there!
I’ll be putting it back together and let’s see what we get. I’m gonna test all of them on pop off pressure and post up results.
DrakeRemoray
L2350DT
Jun 24, 2024
58
Alvarado TX
Tested the one injector that was not firing with the new shim I got from Kubota. It would only go up to 1400psi.
Put the old shim back in and got it right up to 2000psi. Perfectly in specs.
The new shim has a hole in it so it sits flat inside the injector. The old shim does not have a hole in the center and is raised in the injector so it’s providing more compression on the spring thus raising the pressure. Interesting how it all works! Spray pattern looks great as well! 👍
Next issue I have is that the injector pump is not providing any fuel to the #3 injector. Hopefully it’s just trash in the lines. Going to start researching on how it works and how to clean it.
Should I start another thread on injector pump inspection?? That way hopefully we can help others that may run into same issue? Wolfman what’s your thoughts?
