Hi, new member here.
The front tires are closer to each other at the bottom than at the top (camber, I believe) and when I turn sharply, the outer tire looks like it wants to tuck under. I bought it used, is it possible the axle spindles are bent in from hitting curbs, etc, or is this camber normal? If not normal, could I remove the axle/spindles and bend them back? They look awfully thick and hard to bend. Thanks.
