I would assume that the oil pump is not working. It could be the pump or what drives the pump is broken. It might be simply that the oil pickup broke off somehow.
See here for illustrated parts list
- K-PAD - Parts Lists - Illustrated Parts Lists - diagrams
apps.kubotausa.com
The pickup is in the oil pan section and the pump is in the crank case section. The pump appears to be driven by gears and is under a front cover of the engine.
From what I see I would drain the oil and drop the oil pan first to verify if the pickup is still intact and the screen on it is clean or clogged. Beyond that I would probably replace the o ring on the pickup tube if it seems it is loose at all.
If nothing there the move to the front cover removal and see what is going on behind there with the pump. That is much more work to get to (I assume).
