I’m new to this forum so I’m not sure how this works. But I’m hoping to get some advice for a problem I’m having with my BX 23S;
Normally I only use the loader and backhoe but yesterday I went to install the belly mower for the first time in over a year and the mower (raise and lower)mounting linkage underneath the floorboard won’t drop down. The three-point arms go up and down with the control lever movement, but the belly linkage will not raise or lower, it is stuck in the up position. Since they are gravity operated, I thought maybe a little rust was preventing the linkage from dropping down. So I was able to elevate the mower deck up under the tractor and attach it hoping the weight of the deck would force it down with the push of the control lever but It will not go down. I can even stand on the deck and it will not go down. It is stuck in the highest fully up position. I don’t know if this is pertinent, but, I can turn the hydraulic speed control knob that controls how fast the deck is supposed to raise and lower, but I cannot turn the height adjustment knob in either direction, it appears to be frozen in the “top” position. Any thoughts Would be very much appreciated!
