What is this part for?
RpTractorMan
Rochester, NY
I've been looking through this website, my manual and some other online resources and I can't figure out what this part is. It was on the floor where I park the b2601 tractor in the barn. I noticed it when I pulled back into the barn today. I took a look underneath the tractor and I can't figure out what it is or where it goes. It's actually a bolt that fits into what looks like an adjustable threaded bushing.
5,236
1,018
Typically called a Rubber Nut or WELL NUT assuming part of the fitting is not metal but rubber.
As the fastener is tightened down it expand the rubber part securing it to whatever hole it is inserted into.
I have seen used on Vetter motorcycle fairings, fastening glass shower door hinges to fibreglass surround.
Could be used to secure two metal pieces together where access is only on one side precluding use of bolt and nut
5,585
Isn't there a steel nut inside the rubber piece as show in the above picture on the little finger? The part with the arrow is inserted into the hole and when the bolt is tightened the steel nut pulls in and secures the item.
NorthwoodsLife
Oct 15, 2021
1,058
1,006
Wisconsin
Yep. Also can used as a stop-gap temporary oil pan plug. Check your oil!
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,360
1,792
Western MT
That’s a lot of rust. Probably not off the B.
More likely picked up on the tire and dropped in the parking area.
6,404
It's not Stock Kubota.
Did you buy the tractor new?
What implements do you have?
What other Equipment?
What other vehicles are in the barn?
RpTractorMan
Rochester, NY
I originally thought that they might be off something else but it's a dead on match for the paint color. The bolt and the nut are metal. I didn't think the nut was rubber so took a magnet to both just to double check. We have several implements but none are true. Kubota, so I'm not sure why it would have the same matching paint color. I'm pretty sure it's from the b2601 or the kabota bucket attachment. Still can't seem to find where.
6,404
Looks like part of a brake adjuster.
YES you nailed it.
It's a adjuster for drum brakes.
And no it's not off your tractor.
Do you have an equipment trailer or have you done a brake job on anything lately?
Dustball
2016 B2650HSDC
Sep 15, 2023
294
173
Hudson, WI
YES you nailed it.
I've never seen a drum brake adjuster where it looks like one end is a slotted round head screw. Doesn't mean they don't exist- I'm curious where you've seen this type used.
