R RickyJudy New member Equipment 2020 L4060 Kubota Tractor Feb 12, 2024 2 0 1 Kentucky Feb 12, 2024 #1 I have a 2020 Kubota L4060, and I broke off my transmission filter. To replace the broken bracket, I will need to disconnect the metal line. How is that do? RickyJudy
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,705 5,908 113 Sandpoint, ID Feb 12, 2024 #2 Really need to know what variant your working on. And which exact filter as some have 2: Here is a DT variant of the main hydraulic filter: Pull 2 bolts and remove pipe.
R RickyJudy New member Equipment 2020 L4060 Kubota Tractor Feb 12, 2024 2 0 1 Kentucky Feb 12, 2024 #3 How do you disconnect from the plate?
R Russell King Well-known member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 5,157 1,267 113 Austin, Texas Feb 12, 2024 #4 In that version above once the bolts are removed and the rubber hose is disconnected then the hard pipe will just pull out of the filter housing.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,705 5,908 113 Sandpoint, ID Feb 12, 2024 #5 RickyJudy said: How do you disconnect from the plate? Click to expand... Remove bolt 90 to be able to pull pipe out.
